I want to integrate clearcase that is a version management tool with Keil (uvision), can you please tell me how to do that. Thank you.
Regards, Arun
How about reading the section in the uVision Manual which covers this topic?
Thanks for the reply. Well I have already gone through the manual but there is not specifically mentioned how to integrate it. Can you please tell me what setting we need to do for the integration with clearcase.
Thank you.
How "specific" do you need it?
Personally, I wouldn't bother with "integration" - just use the version control tool to check stuff out to a folder, then work on it, then use the version control tool to check it back in.
Simples!
Let me tell you the scenario, I have a requirement where I have to integrate clearcase with Keil, I have to perform all the operation of clearcase from keil itself, when you open the keil tool on the top there is one option svcs, I want what setting I need to do in that so I can perform operation like checkin, checkout and rest all the operation, I tried to do that but I am getting error.
So what "error", exactly, do you get? Is it an error from uVision, or an error from ClearCase - or what?
What have you done to try to resolve this yourself?
Are you sufficiently familiar with ClearCase? In particular, its command-line interface?
