problem in receiving the text serially from port p3.o of At89c51 using pointer.
Hi! i am new to this forum. But still i am sure that this is the place where i could solve the problem regarding my code written in keil c.
Actually, I am working with the voice controlled project. I am sending the speech that has been converted to text through Usb to rs232c cable to p3.0 port of Atmel AT89c51 microcontroller. Now, I am controlling the microcontroller using the keil c. So, I need to receive the text serially using pointers or any other mechanism and the extracted word shoud be compared to either of the commands like right, left,stop,back and provide the appropriate logigic values to motor driving circuit to control the motor. So i have worked with this keil for long time but still i am not getting the respose from the microcontroller side toward the motor driving circuit.
So please help me in moving my project forward.
cheers.
  • Sounds like a basic text parsing exercise, do you have any C coding experience?
    The forum really isn't the place to get your homework done.
  • Having broken your code down into "modules", that makes it much easier to debug.
    Instead of just saying, "i am not getting the respose", you can now look at each "module" to see exactly where it's going wrong:
    1. Is the Serial Data Deception working?
    Clearly, if this is wrong, nothing further is going to work - is it?!
    2. If the serial data reception is OK, is the Text Parsing working?
    3. If the serial data reception & Text Parsing are OK, look at the next step...
    etc,...
  • There are lots of examples how to receive data over UART.
    Then it's simple to decode and decide what to do.
    Remember that the best way to verify your baudrate is to send some characters and verify with an oscilloscope.
  • I am sending the speech that has been converted to text through Usb to rs232c cable to p3.0 port of Atmel AT89c51 microcontroller.
    I fail to see the MAX232(equivalent), the AT89c51, can not handle RS232 signal levels
  • My code for receiving the text like move and back sent from the pc is as below.
    Why my code can't receive the text serially. Can anyone correct my code.
    #include <reg51.h>
    #include <stdio.h>
    #include <math.h>
    #include <string.h> /* ports of l293d for making the motor in forward and backward direction. sbit la=P2^0; sbit lb=P2^1; sbit lc=P2^3; sbit ld=P2^5; sbit le=P2^6; sbit lf=P2^7; void serial(); void delay(); void moves(); void backs(); void lefts(); void rights(); char *rec,c; char *s[1]={"move"}; char *t[1]={"back"}; void main() { SCON = 0x50; /* Set Serial IO to receive and normal mode */ TMOD = 0x20;/*mode 1 and autoreload*/ TCON = 0x40; TH1 = 0xFD;/* value to set 9600 baud rate */ TR1 = 1;/* start timer to Receive */ IE = 0x90; EA = 1; ES = 1; RI=0; while(1) { serial(); if(*rec==*s) { la=1; lb=0; lc=1; ld=1; le=0; lf=1; delay(); } if(*rec==*t); {la=0; lb=1; lc=1; ld=1; le=1; lf=0; delay(); } }} void serial() interrupt 4 {while(1) { while(RI!=1) {} c=SBUF; if(c!=0) { *rec=c; rec++; c=0; RI=0; break; } else return; }}
    void delay()
    { int i,j;
    for(i=0;i<1000;i++);
    for(j=0;j<1000;j++);
  • following the instructions over the entry window
    did you think what you saw in preview was readabele?
  • okay now i am following the stated instruction and can onyone find what is wrong in my code.
    As my code is compiled correctly and hex file has been created but why its not receiving the code sent serially from the pc.
    The code is as follows;
    #include <reg51.h>
    #include <stdio.h>
    #include <math.h>
    #include <string.h>
     sbit la=P2^0;
     sbit lb=P2^1;
     sbit lc=P2^3;
     sbit ld=P2^5;
     sbit le=P2^6;
     sbit lf=P2^7;
      void serial();
            void delay();
            void moves();
            void backs();
            void lefts();
            void rights();
            char *rec,c;
            void main()
            TCON = 0x40;
     IE = 0x90;
            EA = 1;
            ES = 1;
                    RI=0;
                    while(1)
                            serial();
                            if(*rec==*s)
                                    la=1;
                                    lb=0;
                                    lc=1;
                                    ld=1;
                                    le=0;
                                    lf=1;
                                    delay();
                            if(*rec==*t);
                            {la=0;
                                    lb=1;
                                    lc=1;
                                    ld=1;
                                    le=1;
                                    lf=0;
                                    delay();
                    {while(1)
                            while(RI!=1)
                                    c=SBUF;
                                    if(c!=0)
                                    *rec=c;
                                      rec++;
                                            c=0;
                                            RI=0;
                                            break;
                                    else
                                    return;
                            void delay()
    int i,j;
  • void serial() interrupt 4
    {while(1) // first get rid of that
    please explain what in the world made you do that
  • What do you think this actually does:
    if(*rec==*s)
  • Thanx for responding for the my code.
    So in this code, what i am trying to do is receiving the text like move,left right etc sent from the pc.
    So i have tried to receive it using pointer *rec. I have used the serial interrupt(indicated by 4) in keil c to receive the byte from SBUF register.
    After receiving the text completely, i have compared with the text like move which is content of pointer s.Likewise, Back is stored as string in pointer t.
    While(1) is done to make the program work forever and ever as embedded c does not have link with OS.
    While simulating in proteus why it does not respond to dc motor.
  • Ok iam commenting each code properly so that u can understand what i mean.
    Let us suppose that i sending the command like move from the pc serially. And i am going to receive from port 3.0 of microcontroller as follows;
    #include <reg51.h>
    #include <stdio.h>
    #include <math.h>
    #include <string.h>
     sbit la=P2^0; //logic value 0 or 1 given from this port to in 1 pin of l293d
     sbit lb=P2^1;//logic value 0 or 1 given from this port to in 2 pin of l293d
     sbit lc=P2^3;//logic value 0 or 1 given from this port to Enable pin of l293d
     sbit ld=P2^5;//logic value 0 or 1 given from this port to in Enable pin of l293d
     sbit le=P2^6;//logic value 0 or 1 given from this port to in 3 pin of l293d
     sbit lf=P2^7;//logic value 0 or 1 given from this port to in 4 pin of l293d
      void serial();
            void delay();
            void moves();// fxn to make the motor in clockwise direction
            void backs();// function to make motor in anticlockwise direction.
            char *rec,c;
            char *s[1]={"move"};//assigning the text move command to pointer s;
            char *t[1]={"back"};//assigning the text back command to pointer t;
            void main()
            TCON = 0x40;
     IE = 0x90;
            EA = 1;//enable global interrupt
            ES = 1;
                    RI=0;// allow the byte to tranfer
                    while(1)
                            serial();// call the interrupt service routine
                            if(*rec==*s)//comparing the received text with the stored  move command in pointer s;
                                    la=1;
                                    lb=0;
                                    lc=1;
                                    ld=1;
                                    le=0;
                                    lf=1;
                                    delay();
                            if(*rec==*t)//comparing the received text with the stored  back command in pointer s;
                            {la=0;
                                    lb=1;
                                    lc=1;
                                    ld=1;
                                    le=1;
                                    lf=0;
                                    delay();
                    void serial() interrupt 4// interrupt service routine for serial interrupt
                    {while(1)
                            while(RI!=1)//wait until a byte is received
                                    c=SBUF;//when a byte is received place the content from SBUF to c variable
                                    if(c!=0)// whether byte is last character of text or not
                                    *rec=c;// place the byte into content of pointer
                                      rec++;//increment the pointer by 1
                                            c=0;//clear the content of c
                                            RI=0;// disable the RI for next byte
                                            break;//exits from the if statement and moves to while 1 parenthesis.
                                    else//if the character is last the return to the main function.
                                    return;
                            void delay()
    int i,j;
  • Again: please explain what, exactly, you think this actually does:
    if(*rec==*s)
    I think you have a fundamental misunderstanding here.
  • Hello Andrew thanks for replyng. Actually what i mean to do with that code is i wanted to compare the content of pointer s with the content of pointer t.
    So will the pointer rec receive the code in the format {m,o,v,e} or {move}? The problem i am having is do i need to define the address for the interrupt service routine or not?
    The 2nd problem is while using the interrupt service routine, the routine should not have function argument and no return type. But every operation should be carried out in main function and function should b called from main function. So without return type of interrupt service routine, i can't bring back the received text to main fnction for comparison. I think this might b the place where i had done mistake so that my code is not responding.
    I have tried calling the move , back functions from the interrupt routine rather from main function due to no return type but still the code didn't work.
    One mistake i have done in the pointer increment part where i need to use the index for pointing next location as below,
    if(c!=0)
    int i =0;
    rec[i]=c;
    i++;
    c=0;RI=0;
    Can we have the rule to make interrupt routine as return type in keil c?
  • Interrupts don't return values, you have to process things you need too and leave. You also shouldn't spin around in while(1) loops indefinitely.
    You can't do string comparisons with simple pointer comparisons, it doesn't work like that, and I don't think your code does what you need, learn to use things line strcmp(), strncmp(), etc. With string comparisons there must be NUL terminations, and you'll probably want to be able to resync/restart lines.
    Do some implementation and testing on a PC C compiler, get a better grasp of the language and function, as it's hard to learn/debug on embedded, and refine your coding skills.
  • While(1) is done to make the program work forever and ever as embedded c does not have link with OS.
    what is the while (1) doing in the ISR!!!
