hey friends i am using adc 0.1 . it is connected to a potentiometer . my problem is that if i read say 1.75 volts in using the adc than it takes at least 2 reads to get in the correct reading . for eg say the voltage is 1.25 and i change it to 1.5 then the first reading after the chage will b say 1.35 then 1.44 and then 1.5... can any one tell whats the problem ....
the following is my code
IOSET0=IOSET0|0X00010000; // i use a push button to get in the reading while(IOPIN0&0X00010000); AD0CR = 0x01210a02; while(( AD0DR1 &0X80000000)==0); adcdata3 = ( AD0DR1 &0X0000FFC0); adcdata3 = adcdata3 >> 6;
thanks
You got a capacitor on the ADC input?
By the way - why did you think it was a clever idea to play with html tags on the subject line?
no i have not connected a capacitor on the adc input ....
