I have to do digital signal processing using LPC1788. So, can any one give the process for adding the DSP library with above mentioned controller. and link for that one
Why do you have to do it - is it your job? Or your school homework?
In either case, is it right that you should ask other to do your job/homework for you?
ok.
How do i add DSP LIB with LPC1788?
No Mr Andrew Neil
this will never happen again
