SWO on STM32F030
I have previously run debugging with Serial Wire Debug on STM32F4 boards.
Now, I updated everything, have Keil & UVision 5 IDE, an STM32F030 C6, and a ULink 2.
I can't get a serial wire debug window here.
I re-checked all the online How-To guides and it's supposed to be under View->Serial Windows. But there's no entry by that name under this tab.
Why is this? How do I get a Serial Window tab?
  • Hmmm well I'm also pulling up a stock project for an STM32F407, and there's no Serial Viewer under View for THAT one, either. Why's that?
  • So not just Serial Wire viewer, but trying to use the Debug tab once programmed, I get "TRACE HW NOT PRESENT".
    Is there no debug functionality at all?? The specs on it say "Serial Wire Debug", well I'm more than a little perturbed if it has no serial wire debug functionality and those pins are only retaining the NAME and only used for programming.
  • And it says "Target DLL Cancelled- Debugger Aborted!" and quits...
    OK, I found it. The Configure Flash Tools item has to have the Trace Enable unchecked, THEN it'll enter debug mode. And once it's debugging then the View tab has the Serial Windows item under it, that's why I couldn't find it before.
  • Of course there is, you're just mixing up a whole bunch of related TLA's and equating them.
    SWD - Serial Wire Debug, A 2 pin multiplexed JTAG replacement using SWDIO/SWCLK
    SWV - Serial Wire Viewer, A "serial" like equivalent to the old ARM DCC (Debug Communication Channel)
    SWO - Serial Wire Output pin for SWV
    ITM - Instruction Trace Module
    ETM - Enhanced Trace Module
    DWT - Debug Watchpoint Trace
    The SWD is present on the STM32F0x
    On the M3/M4 the SWV is part of the ITM, review core_m0.h and core_m4.h to understand a bit better what's totally missing, vs vendor specific modules that may/may not part of there SoC offerings.
    Ok, so M0 not ITM/ETM, and more limited DWT
    No Trace, remember some limited trace recorded to SRAM, I'd have to find a cite.
    Want to output diagnostics, debug or telemetry, use a serial port (USART)
  • So the basics of what I NEED here are just to be able to stop on breakpoints or user-generated Stop from UVision, and to be able to see where the Program Counter is in the C code and what values are held in variables.
    Is all this still available within the scope of the m0's debug capabilities?
