Hi, if I want to define a 4byte aligned char array in C, then I typically would declare:
__align(4) char acBuf[20];
In C++, inside a class, this unfortunately fails (Error #328: invalid storage class for a class member).
Is there any way to enforce alignment for C++ class members?
Just a shot in the dark: declare the class member inside a union with an int.
Are you serious? - this really would sound like dark art :). I hope very much that there is some more straight forward method?
I don't want to sound like I'm from the 'you should learn to ask a smart question brigade' here, but I'm interested to know why you need/want to do that?
FWIW I know of no method outside the region of dark art.
I am just programming some USB class, and I had the ambition to define the Endpoint buffers inside the class.
Such endpoint buffers need to be aligned on 4-byte adresses, otherwise you get bad crashs (HardFault).
I now recognized, that concerning alignement, the c++ compiler seems to handle the class data like in a struct, if I use the "packed" pragma. So the flexibility of data alignment in a struct seems to be superior than to the data alignement in classes? This really is quite a disapointment (comparing c++ to "normal" c). ... I just recognized, the c++ compiler really located my USB buffers on 1-byte adresses (without getting red ...).
... so thank you for this dark art trick, with this union trick it works ... :)
... sorry about one error in my last post: structs of course would also handle such byte fields packed (without "pack" pragma) ... . So no reason to get red for the C++ compiler here :).
