I am currently using SiLabs IDE which requires the Keil toolchain but having trouble when building my project in the SiLabs IDE. I get the error of :
****************************************************************************** * RESTRICTED VERSION WITH 1000H BYTE CODE SIZE LIMIT; USED: 0356H BYTE (20%) * ******************************************************************************
I am new to coding and could use some help, Thanks.
You are using an unlicensed copy of the Keil tool-set. The demo version you are using has limitations that are documented here.
http://www.keil.com/demo/limits.asp
Purchasing a license will allow you to use the tool without limitations.
I have Keil licensed through the toolchain S/N provided by Silicon Labs. Why would that be an issue if I have only used 0356h of the memory when the limit is 1000h?
Is the problem that you are unable to build or that the tools are restricted?
It looks like the message is just informing you that you are working with a restricted version and that you are at 20% of the limit. There is no indication that the build was unsuccessful.
Is the license installed properly?
Sorry I can't give you definitive help, I'm not familiar with SiLabs IDE, I use the Keil IDE.
As the others have said, that's not an error - that's just information.
Were you also getting some other error(s)?
