No subject
hi sir/mam, looking for your valuable replay.i am using cortex-M4 controller in that i am assigning ADC value uladc_value (unsigned long value) to ch0 (float ) in keil IDE.BUT the problem i am facing is the long value is not getting assigned to float only when i try in keil.when i try the same thing in normal c compiler i am getting the solution.
the equation is as follows,
ch0 =((ulADC_Value)*(3300.0f/4096.0f));--->(not executing in my keil IDE4.2v)
looking for your replay.
thanks and regards in advance,
shyam.
