Unable to activate ADC
I am trying to modify the Blinky program to acquire data in an array from port C.3 using ADC 13 but am unable to run it. I am new to such programming.I am using MCBSTM32E.I have attached the ADC.c file I am using. In addition I am using the Blinky.c file. please help.
//  * Name:    ADC.c
//  * Purpose: low level ADC functions
#include "STM32F10x.h"
#include "ADC.h"
uint16_t AD_last;                         /* Last converted value             */
uint8_t  AD_done = 0;                     /* AD conversion done flag          */
  Function that initializes ADC
    5 MHz operation, 20µs startup time, 600ns track and hold time
void ADC_Init (void) {
  RCC->APB2ENR |= ( 1UL <<  4);           /* enable periperal clock for GPIOC */
  GPIOC->CRL &= ~0x0000F000;              /* Configure PC3 as ADC.13 input    */
#ifndef __ADC_IRQ
  /* DMA1 Channel1 configuration ---------------------------------------------*/
  RCC->AHBENR |= ( 1UL <<  0);            /* enable periperal clock for DMA   */
  DMA1_Channel1->CMAR  = (uint32_t)&AD_last;    /* set chn1 memory address    */
  DMA1_Channel1->CPAR  = (uint32_t)&(ADC1->DR); /* set chn1 peripheral address*/
  DMA1_Channel1->CNDTR = 1;               /* transmit 1 word                  */
  DMA1_Channel1->CCR   = 0x00002522;      /* configure DMA channel            */
  NVIC_EnableIRQ(DMA1_Channel1_IRQn);     /* enable DMA1 Channel1 Interrupt   */
  DMA1_Channel1->CCR  |= (1 << 0);        /* DMA Channel 1 enable             */
#endif
  /* Setup and initialize ADC converter                                       */
  RCC->CFGR    |= ( 3UL << 14);           /* ADC clk = PCLK2 / 8              */
  RCC->APB2ENR |= ( 1UL <<  9);           /* enable periperal clock for ADC1  */
  ADC1->SQR1    =  0;                     /* Regular chn. Sequence length = 1 */
  ADC1->SQR2    =  0;                     /* Clear register                   */
  ADC1->SQR3    = (13UL <<  0);           /* 1. conversion = channel 14       */
  ADC1->SMPR1   = ( 5UL << 12);           /* sample time channel 14 55,5 cyc. */
  ADC1->CR1     = ( 1UL <<  8);           /* Scan mode on                     */
  ADC1->CR2     = ( 7UL << 17)|           /* select SWSTART                   */
                  ( 1UL << 20) ;          /* enable external Trigger          */
#ifndef __ADC_IRQ
  ADC1->CR2    |= ( 1UL <<  8);           /* DMA mode enable                  */
#else
  ADC1->CR1    |= ( 1UL <<  5);           /* enable for EOC Interrupt         */
  NVIC_EnableIRQ(ADC1_2_IRQn);            /* enable ADC Interrupt             */
#endif
  ADC1->CR2    |= ( 1UL <<  0);           /* ADC enable                       */
  ADC1->CR2    |=  1 <<  3;               /* Initialize calibration registers */
  while (ADC1->CR2 & (1 << 3));           /* Wait for init to finish          */
  ADC1->CR2    |=  1 <<  2;               /* Start calibration                */
  while (ADC1->CR2 & (1 << 2));           /* Wait for calibration to finish   */
  start AD Conversion
void ADC_StartCnv (void) {
  ADC1->CR2    |=  (1UL << 22);           /* Start A/D conversion             */
  stop AD Conversion
void ADC_StopCnv (void) {
  ADC1->CR2    &= ~(1UL << 22);           /* Stop  A/D conversion             */
  get converted AD value
uint16_t ADC_GetCnv (void) {
  while (!(AD_done));                     /* Wait for Conversion end          */
  AD_done = 0;
  return(AD_last);
#ifndef __ADC_IRQ
  DMA IRQ: Executed when a transfer is completet
void DMA1_Channel1_IRQHandler(void) {
  if (DMA1->ISR & (1 << 1)) {            /* TCIF interrupt?                   */
    AD_done = 1;
    DMA1->IFCR  = (1 << 1);              /* clear TCIF interrupt              */
#endif
#ifdef __ADC_IRQ
  A/D IRQ: Executed when A/D Conversion is done
void ADC1_2_IRQHandler(void) {
  if (ADC1->SR & (1 << 1)) {            /* ADC1 EOC interrupt?                */
    AD_last = ADC1->DR;
    AD_done = 1;
    ADC1->SR &= ~(1 << 1);              /* clear EOC interrupt                */
#endif
