Hi
I wish to change the directory where the lst and obj files are created using the command line arguments [PRINT and OBJECT]. I wish to keep the output file names same as the input files.I tried invoking the C51.exe from the CommandPrompt and use PRINT[../lst/*.lst] as directive and i get fatal error "file cannot be created".
I guess there is a way to this from a batch file,could some one show it how exactly that goes about?
The best way is to let uVision do it, and then follow its example
I know where is the option in Keil uVision IDE i wish to implement the same thing in SiLabs IDE where there is no such option,only option is to control the arguments to C51.
I am always wary of a method being described as "the best way". Like so many people describe a situation as being "the only thing is ..." when they really mean "the only thing I can think of at the moment is ...".
That said, it is certainly one of the easiest ways.
