lpc1768 embed in labview
Hi everyone,
can anyone help me with the porting of the LPC1768 processor to use in Labview?
I have been going through the NI LabVIEW Embedded for ARM Porting Guide many times now but it is always a fail. The Guide is so confusing and referring to old configurations that are not anymore in Labview 2012.
Thank you
  • Labview is an NI product - it has absolutely nothing whatsoever to do with Keil.
    If you have problems with the NI documentation/support, then you need to take that up with NI.
    Why do you particularly want to use LabView, anyhow?
  • Hi Andrew,
    Thanks for the answer. I am in contact with NI as well but even them seem to be a little vague.
    Anyway my choice of using Labview is just related to my knowledge base. Unfortunately i am new with ARM processor programming and i am not very good with C programming but i can use quite well Labview so this is the reason.
    Also i think that having the possibility of programming with Labview can make things a little faster and easy. I am open to other suggestions as well.
    But Thanks anyway.
