I want to generate interrupt every 1.95ms., but it never hits ISR. Not sure what is the issue as i am quite new to LPC2378 programming. Can some one guide me.
When i put a breakpoint on ISR, it never hits it. Checked all the configuration in peripheral and vector options and all looks to be ok. Where am i doing mistake.
void rtc_tsr(void) __irq {
/* Reset the counter */ VICVectAddr = 0; }
int main(void) { PCONP = 1 << 9; //RTC Power / clock control bit
RTC_CCR = 0x01; // To enable the timer counter
VICVectAddr13 = (unsigned long) rtc_tsr;
VICVectCntl4 = 0x02;
VICIntEnable = 1 << 13 ; // To enable interrupt from RTC source
RTC_CISS = 0x84; // To enable the Subsecond Interrupt & configure for 1.95ms delay
while(1);
return 0; }
