Hi , I'm trying to program the flash of XC2734-40F on infineon UCONNECT , so the only way is using DAS from infineon .
I configure OPTIONS / DEBUG and OPTIONS / UTILITY pages , and from SETTINGS , I configured the FLASH DOWNLOAD OPTIONS , adding the Algorithm for XC2xxxn/B/X-40F OnChip Flash .
The DAS server is running , and DAS interface is correctly detected from KEIL uVision 4 .
I'm using the toolchain version 7.52.0.0 .
If I run the ERASE command from FLASH menu , the tool erase the memory correctly , but when I start the Flash programming , I receive following error :
"No Algorithm found for Address 0x000000"
Someone have some suggestions for me ?
Thanks .
