help reg ARM LPC2378
Hi There, i'm new to LPC2378. can anyone help me to do the external interrupt using EINT0, and EINT1.
i need simple source code for the same. thanks in advance
my mail:karthikec23@gmail.com
  • Isn't it better to do this in the reverse order - you start trying to implement the external interrupt handling based on the excellent documentation already available and the application notes, code bundles released? And you then come back if you are still stuck. Or is that a too simple solution with the bad side effect that you might also learn how it works?
