Freeing alloc_mem() memory...
Greetings:
In the RL-ARM User's Guide, the example for interrupt_ethernet() __irq includes a call to function alloc_mem() to receive an ethernet frame. Here is an excerpt from the sample:
       /* Flag 0x80000000 to skip sys_error() call when out of memory. */
        frame = alloc_mem (RxLen | 0x80000000);
        /* if 'alloc_mem()' has failed, ignore this packet. */
        if (frame != NULL) {
          dp = (U32 *)&frame->data[0];
          sp = (U32 *)Rx_Desc[idx].Packet;
          for (RxLen = (RxLen + 3) >> 2; RxLen; RxLen--) {
            *dp++ = *sp++;
          put_in_queue (frame);
rel:    if (++idx == NUM_RX_FRAG) idx = 0;
        /* Release frame from EMAC buffer. */
        MAC_RXCONSUMEINDEX = idx;
Note that there appears to be no explicit de-allocation of the memory pointed to by OS_FRAME *frame. Shouldn't there be a complimentary call to function free_mem()?
A search for "alloc_mem()" from my IDE finds a similar interrupt_ethernet() __irq, except this one includes the following code. Note the comment about MMU free packet:
         /* Make sure that block is 4-byte aligned */
         for (  ; RxLen; RxLen--) {
            *dp++ = LREG (U32, B2_DATA);
      /* MMU free packet. */
      LREG (U16, B2_MMUCR) = MMU_REMV_REL_RX;
There is still no explicit de-allocation of the memory pointed to by "frame". I wonder if the "LREG (U16,..." somehow does this?
The frightening thing is the first example code (with not even a hint of freeing memory) has been running for quite a while. Is this luck or is something else going on?
Thank you for any comments or recommendations.
  • But the interrupt is just receiving data. So it needs to allocate buffer space to store the received data. Your application then needs to "consume" the received data before it is meaningful to release the buffer memory. The "consume" code isn't part of the interrupt. So no memory release is needed in that interrupt.
