RTX Not Running yet
Ok so basically I'm just trying to create my first RTX application. I have the RTX_Config file for my device included in the project (It's not called RTX_Config.c, its RTX_Conf_LPC21xx.c, I was wondering if that could be the problem) I have rtl.h included im my program and I have the task identified as __task, I commented out the swi handler and replaced it w/ an import, and I changed my target options. However When I cal the os_sys_init function it never calls my task. In fact it ends up in a piece of code that looks like this:
void *__user_perthread_libspace (void) {
  /* Provide a separate libspace for each task. */
  U32 idx;
  idx = runtask_id ();
  if (idx == 0) {
    /* RTX not running yet. */
    return (&__libspace_start);
  return ((void *)&std_libspace[idx-1]);
When this code is called it performs that runtask_id and always gets an idx of 0 evidently this means the kernel isn't running and the program will return to the beginning of main. So my question is has anyone ever encountered this problem, and does anyone know how to fix it? Just for reference here is my program it's supposed to be a simple program that just toggles the state of GPIO0:
#include <rtl.h>
#include <LPC22xx.H>
OS_TID task1ID;
__task void task1 (void);
__task void task1(void) {
        task1ID = os_tsk_self();
        while(1)
                IOPIN0 = ~IOPIN0;
                os_dly_wait(4);
int main()
        PINSEL0 = 0;
        IODIR0 = 0xFF;
        IOPIN0 = 0;
        //task1ID = os_task_create(task1, 1);
        os_sys_init(task1);
        while(1);
If anyone could tell me what I'm doing wrong I would be ecstatic.
