i am working on a project for the automatic power reading using gsm but getting some errors: please check the program and guide me
Build target 'Target 1' compiling codec.c... codec.c(2): warning C318: can't open file 'lcd.h' codec.c(3): warning C318: can't open file 'rtc.h' codec.c(5): warning C318: can't open file 'bcd2ascii.h' codec.c(6): warning C318: can't open file 'serial.h' CODEC.C(35): warning C206: 'lcdInit': missing function-prototype CODEC.C(36): warning C206: 'LCDstr': missing function-prototype CODEC.C(36): error C267: 'LCDstr': requires ANSI-style prototype Target not created
#include<reg52.h> #include <lcd.h> #include <rtc.h> #include<string.h> #include<bcd2ascii.h> #include<serial.h>
sbit sw1=P3^7; sbit sw2=P3^6; sbit sw3=P3^5; sbit buzzer=P2^3; sbit relay=P2^2; sbit rled =P3^4; sbit gled =P3^3; bit flag_sw,flagr=0;
static unsigned char k=0,s=0x84,*result,h,unit=0; unsigned char inc=23,check_flag=0,month_flag=0,month; unsigned char *time,*res; unsigned char idata byte1[100]; unsigned char *date,*u,i,j,a=0,b,c,d;
void main() { TMOD=0x20; // serial communication intialization TH1=0XFD;SCON=0X50;TR1=1;i=0; IE=0X91;IT0=0;
lcdInit(); // LCD intialization LCDstr("AUTOMATIC POWER",0x80); LCDstr("METER READING",0xc0); delay(2000);
gsm_check();gsm_rec(); //gsm modem intialization gled=0;rled=1;buzzer=1;relay=1;
while(1) //super loop {
//time display LCDstr("DATE ",0x80); LCDstr("TIME",0xc0); date=getDate(); LCDstr(date,0x86); time=getTime(); LCDstr(time,0xc6); flag_sw=0;delay(1000);
//units display putComL(0x01); LCDstr("UNITS=",0x80); putComL(0x86); unit=getCharE(0x15); u=bcdtoascii(unit); LCDstr(u,0x87);
delay(2000);
/**************checking********************/
a=getCharE(0x04); // gsm modem sending sms if(a>=28 ) { gsm_check(); delay(200); ES=0; unit=0; putCharE(unit,0x15); rled=0;gled=1; gsm_send(byte,"number"); }
//else case
if(a>=16 & d==c){month_flag=1;} else month_flag=0;month_flag=getCharE(0x20);
if(check_flag==0 & month_flag==1 &flagr==0){flagr=1;relay=0;rled=0;gled=1;buzzer=0;delay(100);buzzer=1;} else if(check_flag==1 ){ gled=0;rled=1;buzzer=1;relay=1;} delay(1000);
//receving sms for(j=0;j<100;j++) {if(byte1[j]=='*' &byte1[j+1]=='P' & byte1[j+2]=='A'& byte1[j+3]=='I'& byte1[j+4]=='D') {ES=0;LCDstr("received",0xc0); a=1;check_flag=1;putCharE(check_flag,0x10); gsm_rec(); }} //time setting
if(sw3==0){enter_time();} delay(1000);k=0;
Please Guide Me...
can you Please tell me some more programs to study.
All other Keil samples!
Also, see here:
http://c-faq.com/
stealing stuff you don't understand out of programs that aren't yours,
When was last time you have stolen things that ARE yours?
This is how it works (used to work) in the Keil tools.
http://www.keil.com/support/docs/2393.htm
Jon
stolen things that ARE yours? aka code reuse
I've already given you a link to a whole load of resources - did you follow it?
Sir. On building the target a message appears like this:
Build target 'Target 1' assembling STARTUP.A51... compiling code.c... C51 FATAL-ERROR - ACTION: PARSING SOURCE-FILE ERROR: PREPROCESSOR: MACROS TOO NESTED C51 TERMINATED. Target not created
What does this means?
surprise! it means MACROS TOO NESTED
if you do not know what a nseted macro is then
macro a .... endm
macro b a // this is macro a nested .... endm
somewhere in the docs it staes how many levels th tools can handle, but if you go more than, say, 2 deep, your code is unreadable anyhow
