Problem on debugger with extern variable
Hello everybody,
I have a problem with a global variable. This variable is declared as extern.
It is reset to 0 automatically inside the Keil µVisionb 4 debugger when used in a function written in different C file.
I make deeper reference.
I declared variable in a header like this
#ifdef __VAR_G
        #define __DEF
#else
        #define __DEF extern
#endif
__DEF uint32_t SystemCoreClock;
__DEF   uint32_t Init_OK;
I use this variable twice :
Firstly in a.c file
#define __VAR_G
#include "stm32f4xxiut.h"
void SystemInit()
    Init_OK = Init_OK | HSE_FAIL;
    SystemCoreClock=16000000;
Secondly in b.c file
void main()
    int b=0;
    if (Init_OK==1)
        b=2;
My problem is the following.
In the keil debugger, with STM32F4XX, first, system init is executed. The both variable are declared as global and a value is assigned to them. Then, the core branch to main and the both variable are reset to zero in spite of the extern keyword used inside the definition.
Do you know why there is this strange behaviour.
Thank you.
  • Then, the core branch to main and the both variable are reset to zero in spite of the extern keyword used inside the definition
    ALL variables, except those in noinit (I)RAM segments will be set to zero on the entry of main.
    I do not see what "the extern keyword" has to do with it
  • ALL variables, except those in noinit (I)RAM segments will be set to zero on the entry of main.
    I think you meant to say that all variables, except those in noinit, will be initialised just prior to the entry of main (and not necessarily set to zero).
  • Ok, it is a normal behaviour.
    I don't know that the entry in main has this kind of effect.
    Then, how can I do to avoid this problem and locate variable in noinit (I)RAM segments ?
    Thanks.
  • It's not so much the behaviour of main() that should have you surprised. That's perfectly ordinary, well-defined behaviour of every C program.
    The thing you should wonder about is that System_Init() is called before main(). That's not something a C program usually allows. So this function SystemInit() must be rather special.
    The question you should have asked yourself earlier is: what limitations are documented in your system manual about what you can and cannot do in this function? In particular, are you sure you're supposed to use ordinary C variables in there, as opposed to, say, only set up some special purpose registert to configure clocks, enable peripherals, etc.?
  • I found a solution by making these variables in noinit zone with zero_init option in declaration.
    This avoid resetting selected variable at the entry inside main function.
    Thanks a lot for your help and this amount of knownledge you bring to me.
  • This avoid resetting selected variable at the entry inside main function.
    this is not done "inside main function" it is done by the "secret sauce initializer code" that the linker insert before main()
  • Just note that the Cortex chips have a design where the processor sets up the stack, allowing a C function to get activate directly on reset with zero assembler instructions involved. And the core performs the required background stuff to allow interrupt handlers to be ordinary C functions - no interrupt keyword needed.
    But if the reset code is written in C, that code must still be written based on the knowledge that the processor hasn't been fully configured yet and that C libraries etc can't be used.
    The C standard doesn't really consider C functions called before main() - it considers main() to be the entry function and specifies a number of rules that must be fulfilled at entry to main().
    I contest your assessment of that being a "solution". It's actually more of the same problematic behaviour piled upon what's already there. But two wrongs don't make a right.
    The real problem is that you're doing stuff in the wrong place. SystemInit() is a special function that exists for a couple of very specific purposes. Initializing ordinary C variables is not one of those. You ignore such details at your own peril.
    The solution is for you to stop fighting your tools and just use them as they're meant to. Leave initialization of C variables to the C compiler and linker or, if you really think you have to do it manually, do it in main().
    In other words, you created that problem yourself. All it woould take to solve it is to stop creating it.
  • I constest your assesment.
    System_Init() initializes clock.
    These two variables are to save clock frequency and the second is a kind of register to know what is working or not inside initialization without checking every register.
    It is not classical C variable for my program which them will be declare and initialize inside main.
    This is absurd!
    Here is reset handler of my LPC1788 bootloader:
    Reset_Handler      PROC
                                    EXPORT  Reset_Handler             [WEAK]
                                    IMPORT  SystemInit
                                    IMPORT  __main
                    IF      :DEF:MBOOT
                    IMPORT  sdram_init
                    ENDIF
                                    LDR     R0, =SystemInit
                                    BLX     R0
                    IF      :DEF:MBOOT
                    ; init SDRAM before scatter loading starts...
                    LDR     R0, =sdram_init
                    BLX     R0
                    ENDIF
                                    LDR     R0, =__main
                                    BX      R0
                                    ENDP
    SystemInit call call _BEFORE_ scatter loading (__main...)!
    There is no justification for making that variable non-zero init.
    I suggest to you that you actually listen to us, instead of going into a tail spin...
  • System_Init() initializes clock.
    Exactly. And that's all you're supposed to do in there. Writing normal C variables is stricly outside the set of things you're allowed to do in there.
    And why on earth would you need a variable to store this in, although it is beyond all reasonable doubt a compile-time constant?
    Except that it's not any kind of register. It's a C variable.
    Now you're being ridiculous. Well, either that, or you have not the slightest idea what the words you're using actually mean.
    Because, in contrast to what you say now, that's exactly what those things are: plain ordinary C variables. Your own code treats them every bit as if it were one: you set the variable to some value in one place, and expect it to keep that value until modified by an assignment later.
  • The following is straight from ST's system_stm32f0xx.c (my emphasis added) - I imagine that the OP's STM32F4xx would be similar:
      * @file    system_stm32f0xx.c
      * @author  MCD Application Team
      * @version V1.0.0
      * @date    23-March-2012
      * @brief   CMSIS Cortex-M0 Device Peripheral Access Layer System Source File.
      *          This file contains the system clock configuration for STM32F0xx devices,
      *          and is customized for use with STM32F0-DISCOVERY Kit.
      *          The STM32F0xx is configured to run at 48 MHz, following the three
      *          configuration below:
      *            - PLL_SOURCE_HSI (default): HSI (~8MHz) used to clock the PLL, and
      *                                        the PLL is used as system clock source.
      *            - PLL_SOURCE_HSE          : HSE (8MHz) used to clock the PLL, and
      *            - PLL_SOURCE_HSE_BYPASS   : HSE bypassed with an external clock
      *                                        (8MHz, coming from ST-Link) used to clock
      *                                        the PLL, and the PLL is used as system
      *                                        clock source.
      * 1.  This file provides two functions and one global variable to be called from
      *     user application:
      *      - SystemInit(): Setups the system clock (System clock source, PLL Multiplier
      *                      and Divider factors, AHB/APBx prescalers and Flash settings),
      *                      depending on the configuration selected (see above).
      *                      This function is called at startup just after reset and
      *                      before branch to main program. This call is made inside
      *                      the "startup_stm32f0xx.s" file.
      *      - SystemCoreClock variable: Contains the core clock (HCLK), it can be used
      *                                  by the user application to setup the SysTick
      *                                  timer or configure other parameters.
      *      - SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must
      *                                 be called whenever the core clock is changed
      *                                 during program execution.
    So they do seem to be suggesting that the user code can just read this global?!
    This will work provided you call SystemCoreClockUpdate() before the user code first uses the SystemCoreClock variable - but the documentation above certainly doesn't make that clear!
