SAM7X RL-USB Library not work
Hi, I've made a board to use SAM7X's USB Port. the board works correctly with other functions like buttons and LEDs also SAM-BA work correctly (during test of SAM-BA I found that SAM-BA 2.12 don't support USB3 port). now I want to test it's USB feature but when I compile any example of USB (from atmel's website or other resources) the Keil compiler give errors about headers codes like this error :
Undefined symbol USB_Connect (referred from main.o).
Undefined symbol USB_Init (referred from main.o).
with this errors I searched the help of keil and found migration page and RL-USB library and completely changed my codes to make it compatible with the library. after changing the code with challenges and obviating the errors, program compiled successfully and I programmed it into the chip. but after connecting it to USB port of computer, the windows (7 & 64bit) indicated "USB device not recognized" error.
I think that the hardware don't have problems because the SAM-BA works correctly. what is the problem ? do I need to make any change in pins status other than DDM and DDP ?
#include <RTL.h>
#include <rl_usb.h>
#include <AT91SAM7X256.H>
int main (void) {
  static U8 but_ex;
         U8 but;
         U8 buf[1];
  usbd_init();                          /* USB Device Initialization          */
  usbd_connect(__TRUE);                 /* USB Device Connect                 */
  while (1) {                           /* Loop forever                       */
    but = (((AT91C_BASE_PIOA->PIO_PDSR ^ (0x1F << 21)) >> 21) & 0x1F);
    if (but ^ but_ex) {
      buf[0] = but;
      usbd_hid_get_report_trigger(0, buf, 1);
      but_ex = but;
Please help me solve this problem.
Best Regards.
  • Don't you feel that a crucial step after managing to compile code without warnings or errors from the compiler is to switch tools and start debugging? Or you think your part of the problem ends when you can compile?
  • > I've made a board to use SAM7X's USB Port...
    Likely, hardware issue.
    1) Check the connections between MCU USB pins and the USB connector. DDP --- D+ (3) DDM --- D- (2)
    On custom boards, these connections are often swapped.
    2) Crystal frequency
    Keil and Atmel examples are tuned for a 18.432MHz crystal on AT91SAM7X-EK board.
    To apply other frequency, you have to tune the PMC_USBDIV value
    SAM7.s
    PMC_USBDIV      EQU     (0x03<<28)      ; USB Clock Divider
    Tsuneo
  • yes that's right but I use debug tool to solve problems when the code don't have structural problems like headers replacement.
  • I used 18.432MHZ crystal. I think the hardware don't have problem because the SAM-BA works correctly, is this true ?
    with the changes below the problems resolved and PC detected the board and installed it but finally I used Atmel's sample and have problem with keil's sample yet.
    #include <AT91SAM7X-EK.h>
    #include <type.h>
    #include <usb.h>
    #include <usbcfg.h>
    #include <usbhw.h>
    #include <demo.h>
    AT91S_PIO * pPIO_Led = AT91D_BASE_PIO_LED;  /* Global Pointer to PIO */
    AT91S_PIO * pPIO_Sw  = AT91D_BASE_PIO_SW;   /* Global Pointer to PIO */
    U8 InReport;                                /* HID Input Report */
                                                /*   Bit0..4: Buttons */
                                                /*   Bit5..7: Reserved */
    U8 OutReport;                               /* HID Out Report */
                                                /*   Bit0..3: LEDs */
                                                /*   Bit4..7: Reserved */
     *  Get HID Input Report -> InReport
    void GetInReport (void) {
      U32 key;
      key = pPIO_Sw->PIO_PDSR;                        /* Read Pin Data */
      InReport = 0x00;
      if ((key & AT91B_SW1) == 0) InReport |= 0x01;   /* Check if SW1 is pressed */
      if ((key & AT91B_SW2) == 0) InReport |= 0x02;   /* Check if SW2 is pressed */
      if ((key & AT91B_SW3) == 0) InReport |= 0x04;   /* Check if SW3 is pressed */
      if ((key & AT91B_SW4) == 0) InReport |= 0x08;   /* Check if SW4 is pressed */
      if ((key & AT91B_SW5) == 0) InReport |= 0x10;   /* Check if SW5 is pressed */
     *  Set HID Output Report <- OutReport
    void SetOutReport (void) {
      if (OutReport & 0x01) pPIO_Led->PIO_CODR = AT91B_LED1; else pPIO_Led->PIO_SODR = AT91B_LED1;
      if (OutReport & 0x02) pPIO_Led->PIO_CODR = AT91B_LED2; else pPIO_Led->PIO_SODR = AT91B_LED2;
      if (OutReport & 0x04) pPIO_Led->PIO_CODR = AT91B_LED3; else pPIO_Led->PIO_SODR = AT91B_LED3;
      if (OutReport & 0x08) pPIO_Led->PIO_CODR = AT91B_LED4; else pPIO_Led->PIO_SODR = AT91B_LED4;
    /* Main Program */
    int main (void) {
      /* Enable Clock for PIO */
      AT91C_BASE_PMC->PMC_PCER = (1 << AT91C_ID_PIOA);         /* Joystick */
      AT91C_BASE_PMC->PMC_PCER = (1 << AT91C_ID_PIOB);         /* LEDs     */
      pPIO_Led->PIO_PER  = AT91B_LED_MASK;      /* Enable PIO for LED1..4  */
      pPIO_Led->PIO_OER  = AT91B_LED_MASK;      /* LED1..4 are Outputs     */
      pPIO_Led->PIO_SODR = AT91B_LED_MASK;      /* Turn off LED's ("1")    */
      USB_Init();                               /* USB Initialization */
      USB_Connect(__TRUE);                      /* USB Connect */
      while (1);                                /* Loop forever */
    also added hiduser.c usbcore.c usbdesc.c usbhw_SAM7X.c usbuser.c to the project and configured usbcfg.h.
    Thanks,
    Best Regards.
  • I'm not sure, why above code change solves USB enumeration problem.
    Abvoe change swaps just LEDs/key switches/joystick ports from the original to yours.
    The change doesn't directly concern to USB setup.
    Maybe, one of the original ports causes power failure on your board.
    Tsuneo
