Sometimes in cortex M3 there are registers which get cleared on reading. like some of int registers.
Now if use
uint32_t dummy = read_register();
then if will clear the register but compiler generate warning that dummy not used again, which is ok, now this can be removed by if(dummy){}.
But can it be done by below statement:
(void)(read_regsiter());
Will it clear the register also
Not only in Cortex-M3 - it's very common & widespread...
"Not only in Cortex-M3 - it's very common & widespread..."
Almost "every" UART has such registers.
