I am using the STM32F4 Discovery board (Cortex M4F) with uVision. I find the Logic Analyzer very useful, but I experience the following problem. After a random time (10, 20, even 30 seconds) of correct working, LA freezes, with the error message :
"Cannot access memory"
The only way to make it work again is to close and restart uVison, AND power cycle the board. Just closing and restarting uVision is not enough.
As this is quite annoying, I am wondering if there is a way to prevent this, and, in a subordinate way, if it is possible to re-enable LA without the need to power-cycle the board.
-Fred
it looks like this has to do with the data reads (DWT) from the onboard ST Link. Can you please raise a support request and attach your example?
BR, /th.
I have the same problem on the STM32f4Discovery. The logic anaysator freezes after a short time (~5sec/~500sec). Also in the Keil-example (apnt_230) for this Board... How can I fix that? Or this is due to the limitation of ST-Link-debugger?
Greez Na
