I'm using array of buffer structure to store the data sent by external chip interfaced by SPI. it contains the data pointer and next pointer. The storage of data sent is triggered by the external GPIO interrupt. Inside "EINT1_IRQHandler" i'm calling a function to read a frame sent by chip.
typedef struct _buffer_t { struct _buffer_t *next; uint8_t *dptr; uint8_t len; uint8_t buf[SIZE]; } buffer_t;
frame_read(buffer_t *buf) { uint8_t i,length,*data=0,temp; if (!buf) return; SSEL_CLR(); spi_send(FR); length=spi_send(0); buf->dptr = &buf->buf[SIZE-length]; for (i=0; i<length; i++) { temp = spi_send(0); *data++= temp; } SSEL_SET(); }
now at buf->dptr = &buf->buf[SIZE-length]; some times it gives me Imprecise error, according to different documents location of actual fault is hard to locate. So i used fault handler and MPU functions to debug this error. The output of which is as follows
In Hard Fault Handler SCB->HFSR = 0x40000000 Forced Hard Fault SCB->CFSR = 0x00000082 Memory Management fault: Data access violation. SCB->MMFAR = 0x0000000e r0 = 0x00000077 r1 = 0x00000062 r2 = 0x00000006 r3 = 0x0000001f r12 = 0x0fbbc8cb lr = 0x000020cb pc = 0x000020d8 psr = 0x21000023
now according to this there is data access violation at memory address 0x0000000e, which is part of 512 k flash memory. Flash memory is used for storage of program instructions and constant data types. I think buffer structure should be stored in the SRAM.
"I think buffer structure should be stored in the SRAM."
Exactly - so fix your bugs where you make use of a pointer that hasn't been initialized, or where you use index outside bounds resulting in memory overwrites resulting in broken pointers.
How clever do you think it is to make use of a NULL pointer in your code. Did you totally forget to debug these few lines of code, while looking at the contents of your variables?
By the way - why are you aligning your data in the last part of the buffer?
