Double pointer as parameter doesn't work with typedef
I am trying to pass a pointer by reference to a function and get that function to point my pointer at a structure that it finds.
char get_structure(STRUCTURE **ptr)
    if(foundstructure)
        *ptr = &theStructure;
        return 1;
    return 0;
This works how I expect it, but when I try and declare the function prototype in the header file:
char get_structure(STRUCTURE **ptr);
I always get a compiler error:
error C141: syntax error near '*', expected ')'
I don't get an error when this is a defined type like char, int or long, but I get the error when this is a pointer to a typedef that I have defined.
How can I declare this in my header file without an error?
Nathan
