Device : ST10F269 Toolset: µVision V4.72.9.0 / C166 V7.53.0.0 / L166 V5.25
Because the size of my DGROUP exceeds 16K I changed the memory model settings from : MEDIUM 16KB RAM and 16KB ROM to : MEDIUM 16KB RAM and 32KB ROM
Afer change target builds successfully however the CAN1 no longer services the RX interrupt service routines on incoming CAN msgs.
changing the memory model to :
HLARGE 16KB RAM and 16KB ROM or XLARGE 16KB RAM and 16KB ROM
renders the same results -> no CAN RX
Any ideas? Thanks!
Hmm... DGROUP is the data group, right? If so, why did you go and change the code size of your memory model to try and overcome a data size limitation?
