I have installed Keil MDK for ARM in my PC. Copied Stellarisware folder in C drive.
I opened can_fifo.uvproj & run, it shows no error. can_fifo.h is stored at C:\StellarisWare\boards\ek-lm3s8962\can_fifo
When I copied this project at another location e.g.E:\New folder\can_device_fifo When i run it , it shows error 'Can not open source input file "inc/hw_memmap.h": No such file or directory'
Similarly if i create a new project in E: or D: drive & suppose i am adding a file to the project e.g. simple_rx.c
When i build it shows same error 'Can not open source input file "inc/hw_memmap.h": No such file or directory'
Please help me in solving this problem.
Consider the include paths specified in the project options, and if those exist in the new ones?
Options -> C/C++ -> Include Paths
Thanks for the reply.
I have given include paths. Now still i am getting following 2 errors
Error: L6218E: Undefined symbol UARTStdioInit (referred from simple_rx.o). Error: L6218E: Undefined symbol UARTprintf (referred from simple_rx.o).
This two symbols are from uartstdio.h
Perhaps, but this is a LINKER error indicating an absence of an object or library file containing the code behind the "references" to other code in the include file, and use in your source.
