HI ERIK AND DHAVAL SOLANKI
PLEASE CLARIFY ME THE MISTAKE I VE DONE HERE, THIS THE PROGRAM TO INTERFACE FOUR SEVENSEGMENT LEDS (MULTIPLEXING), IN THIS PROGRAM THE DATA WHICH IS STORED IN 90H,91H,92H,93H ARE NOT DISPLAYED IN PORT P1. PLEASE GIVE ME YOUR SUGGESTION, NO ERROR DISPLAYED BUT THE ANSWER IS NOT OBTAINED
;COUNTER PROGRAM ORG 0000H LJMP MAIN ;------------------------------------- ORG 000BH LJMP T_I_CALC ;------------------------------------- MAIN: MOV R2,#0 MOV R3,#0 MOV R4,#0 MOV R5,#0 MOV TMOD,#00000001B MOV TL0,#00H MOV TH0,#0FFH MOV IE,#10000010B SETB TR0 ;------------------------------------- L1: MOV P2,#11110111B MOV R0,93H MOV P1,@R0 MOV P2,#11111011B MOV R0,92H MOV P1,@R0 MOV P2,#11111101B MOV R0,91H MOV P1,@R0 MOV P2,#11111110B MOV R0,90H MOV P1,@R0 ; MOV R6,#0FFH ;L10: MOV R7,#0FFH ;L9: DJNZ R7,L9 ; DJNZ R6,L10 SJMP L1 ;-------------------------------------- T_I_CALC: CLR TF0 CLR TR0 CLR A MOV A,R2 MOV DPTR,#DAT MOVC A,@A+DPTR MOV 90H,A INC R2 CJNE R2,#10,L4 L4: JC L5 MOV R2,#0 CLR A MOV A,R3 MOVC A,@A+DPTR MOV 91H,A INC R3 CJNE R3,#10,L6 L6: JC L5 MOV R3,#0 CLR A MOV A, R4 MOVC A,@A+DPTR INC R4 MOV 92H,A CJNE R4,#10,L7 L7: JC L5 MOV R4,#0 CLR A MOV A,R5 MOVC A,@A+DPTR INC R5 MOV 93H,A CJNE R5,#10,L8 L8: JC L5 LJMP MAIN ;--------------------------------------- L5: MOV TL0,#000H MOV TH0,#0FFH SETB TR0 RETI ;----------------------------------------- DAT: DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H ;----------------------------------------- END ;-----------------------------------------
if some code (your other post gives an assembler error), you learn NOTHING by "doing it another way" if you do not resolve your problems by figuring out the reason, you will NEVER make any progreaa
THANK YOU FOR YOUR BEST COLLECTIONS,I TRIED TO FIGURE OUT THE PROBLEM IN SO MANY WAYS, IT DID NOT WORK PROPERLY, STILL EVEN AFTER MAKING CORRECTION AS PER YOUR QUOTE "#" IT DOES NOT WORK .SURE I WILL GO THROUGH YOUR COLLECTIONS
ERIK, I TRIED WITH THE ABOVE SAME PROGRAM BY USING REGISTER BANK0 AND BANK1 ALTERNATIVELY , WHILE SWITCHING OVER FROM RS0 TO RS1 IT GENERATES SOME RANDOM VALUES IN RS1 REGISTERS, DO YOU KNOW CAUSE?
yes, but I am not going to do your homework for you. Refer to "the bible" and find out. Stop typing with all capitals it is difficult to read and I do not like my eyes hurting.
Step1: Read the Architecture (more importantly internal RAM structure) of 8051 Step2: Read the addressing modes and then the instruction set.
You are trying to read the RAM location 93H. Let me ask you a question, "Are you sure that you can read that memory location of internal RAM?" Are you allowed to read/write the memory location above 0x7FH, that are not dedicated for SFR? If you dont have any idea, follow step1.
THANK YOU ERIK, I DONT NEED YOUR HELP, I DID NOT ASK YOU TO DO MY HOME WORK, JUST I CAME TO THIS FORUM FOR DISCUSSION AND CLARIFICATION, DONT BEHAVE LIKE YOU KNOW EVERYTHING,BUT ITS MY HABIT OF TYPING IN CAPITAL LETTER I CANT CHANGE THIS JUST FOR YOU.YOU NEVER THING TO CHATT TO ME LIKE THIS FURTHER, DONT YOU HAVE MANNERS?USE LIMITED WORDS.
it will be fun (more importantly a learning experience) reading the thread and the comments made to this guy Richard Marshall BEng(Hons) by other people in the thread.
here again is one of those posts "I want help for free, but darn it, I want it on MY conditions".
I understood my mistake, i wont repeat it again...
Erik, I am so sorry yaar, but one think is true that you are a wise man in micro controller.I accept that.As my apology, look at in this comment, i ve used everything in small letters except the noun.......sorry genius...dont forgive me but forget my last comment
Erik, i ve gone through the bible you ve given named:80C51_FAM_ARCH_1 page no:3 sentence is: Figure 9 gives a brief look at the Special Function Register (SFR) space. SFRs include the Port latches, timers, peripheral controls, etc. These registers can only be accessed by direct addressing. Sixteen addresses in SFR space are both byte- and bit-addressable. The bit-addressable SFRs are those whose address ends in 0H or 8H. my question: named:The 8051 Microcontroller and Embedded Systems Using Assembly and C-2nd-ed author:muhammad ali mazidi page no:30(avalable in pdf format) in this book there are only 11 bit addressable sfr's,Thy are:P0,P,02,P3,TCON,SCON,IE,IP,PSW,ACC,B which one correct.if the bible is true then which are remaining 5 bit addressable SFRs, and will it end with 0h and 8h
Erik, i ve gone through the bible you ve given named:80C51_FAM_ARCH_1 page no:3 sentence is: The next 16 bytes above the register banks form a block of bit-addressable memory space. The 80C51 instruction set includes a wide selection of single-bit instructions, and the 128 bits in this area can be directly addressed by these instructions. The bit addresses in this area are 00H through 7FH. my question: named:The 8051 Microcontroller and Embedded Systems Using Assembly and C-2nd-ed author:muhammad ali mazidi page no:24(avalable in pdf format) in this book the author has told the memory location from 20h to 2fh is alone bit addressable ... and rest of the memory is byte addressable then.. then which one is correct?
doc.nit.ac.ir/.../3-Mazidi-8051.pdf
One might hazard that 128 bits fit in 16 bytes
yes correct, what about the first question
