I need help. I'm using the IAP, secondary bootloader. I'm having a problem erasing sectors. When I try to erase a sector, it hangs at function "iap_entry(command, result)" in erase function.
It passes through Prepare function successfully.
The code:
#define IAP_LOCATION 0x7FFFFFF1 #define IAP_CLK 48000000 #define AP_ADDR 0x10000// where the user app located typedef void (*FP)(void);/* run the user application from pre-specified address*/ #define iap_entry(a, b) ((void (*)())(IAP_LOCATION))(a, b) unsigned long command[5]; unsigned long result[3];
The ERASE FUNCTION:
unsigned long IAP_EraseSec (unsigned long StartSecNum, unsigned long EndSecNum) { if (EndSecNum < StartSecNum) return IAP_STA_INVALD_PARAM; command[0] = IAP_CMD_EraseSec; command[1] = StartSecNum; command[2] = EndSecNum; command[3] = IAP_CLK / 1000; _printf("\r\n*******ERASE3************"); iap_entry(command, result); _printf("\r\n*******ERASE4************"); return result[0]; }
The PREPARE FUNCTION:(that one works ok)
unsigned long IAP_PrepareSec (unsigned long StartSecNum, unsigned long EndSecNum) { if (EndSecNum < StartSecNum) return IAP_STA_INVALD_PARAM; command[0] = IAP_CMD_EraseSec; command[1] = StartSecNum; command[2] = EndSecNum; command[3] = IAP_CLK / 1000; _printf("\r\n*******ERASE3************"); iap_entry(command, result); _printf("\r\n*******ERASE4************"); return result[0]; }
Can anyone help me?
thanks
Sorry I've posted the wrong prepare code function:
unsigned long IAP_PrepareSec (unsigned long StartSecNum, unsigned long EndSecNum) { if (EndSecNum < StartSecNum) return IAP_STA_INVALD_PARAM; command[0] = IAP_CMD_PrepareSec; command[1] = StartSecNum; command[2] = EndSecNum; iap_entry(command, result); return result[0]; }
The only thing I can think is that you are deleting a sector whe you current code resides.
Yeah..I don't think so..
Because the user code begins at sector 9 (0x10000).. And I send the command to erase exactly this sector.
An important thing I forgot to say is the sector is erased correctly! In Flash Magic we have a tool that displays the Memory and I´ve compared before and after and the sector 9 really is erased!
I put some debugs in the code an I've found exactly where it stops. In Erase function:
unsigned long IAP_EraseSec (unsigned long StartSecNum, unsigned long EndSecNum) { ... iap_entry(command, result); // THE PROBLEM IS RIGHT HERE! // nothing after that is executed }
Thanks!
Maybe is something wrong with this line?
You should not play with #define like that.
A more readable solution is:
typedef void (*IAP)(unsigned[],unsigned[]); IAP iap_entry = (IAP)IAP_LOCATION; unsigned cmd[5]; unsigned res[3]; ... cmd[0] = PREPARE_SECTOR; cmd[1] = start_sector; cmd[2] = end_sector; iap_entry(cmd,res); ... cmd[0] = ERASE_SECTORS; cmd[3] = CCLK / 1000; iap_entry(cmd,res); ...
Yeah.. I've already tried that way, but also without success...
One weird thing I discover is: In the 3rd parameter of ERASE command, "System Clock Frequency in kHz", when cclk = 24000 (24MHz) the program stops..
But when I put a really small value in this parameter, like cclk=24. The program doesn't stop but also doesn't erase the sectors...
What should be de cfgs of IRAM1 and IRAM2 for the sec bootloader code?
At the moment the Secondary Bootloader share the same config of User code Both code are configured : IRAM1 = 0x40000040 Size: 0x8000 IRAM2 = 0x7FD00000 Size: 0x2000
... since you have not seen fit to reveal which chip.
sector erase is very chip dependent. And I do not recognize your IRAM settings matching any chip I know
Sorry.. It is LPC2368.
I remember a similar problem we had and the cause is that our bootloader and user application were using different clock settings (system settings). The boot was working ok on his own so was the user application but the jump from one to the other didn't work.
I don't if this relevant to you but it may help you.
Additional to my previous comment.
The user application was trying to use systen setting of the bootloader and that was affecting his usage of UAR and others. Was solved reseting systems settings to correct values.
Thanks for you answer Christian. But I think then my problem isn't this..
The problem is a little before run the user code. Is in Erase function of IAP.
For me maybe is some problem in IRAM config, or in the delaration of iap_entry.. I don't know.. I'm running out of options..
If someone have already worked with IAP and works ok, please tell me the compiler options used. And the If someone have already worked with IAP and works ok, please tell me the compiler options used.
By the way.. I'm using uVision 4.
many have been bitten by their watchdog when erasing.
Hey! I've found my stupid error. The line that should clear all interrupts was in the wrong place. So another interrupt was set before ERASE function be called.
Thank you all for the help!
Congratulations.
I should have cut/pasted some more source code lines in my previous post - complete with interrupts and watchdog-kick.
