Reading Data using I2C
hi
i want to read the temperature using i2c
is there any simplest code ?
i mean just send address and read data
no more
  • is there any simplest code ?
    use a derivative (SILabs, NXP, ...) with hardware I²C they all come with ready made code.
    PS there is NO SUCH THING as i2c, it is I square C. Yes, I know it is "common" but that does not make it right.
  • "PS there is NO SUCH THING as i2c, it is I square C. Yes, I know it is "common" but that does not make it right."
    Oops. Tell that to NXP (formerly Philips, aka creators of the bus) ;)
    Read the "keywords" section on first page of:
    www.nxp.com/.../UM10204.pdf
    It is an established standard that when typography can't support superscript characters, a non-superscript digit is used. What exactly would be the alternative? IIC? A large percentage of I2C users would probably not recognize that term. And it is used exactly zero times in NXP:s linked manual. While that manual contains a number of i2c references - in keywords, email addresses, web links, ...
  • It is an established standard that when typography can't support superscript characters
    the 'typography' of this forum clearly can support superscript characters.
    the I2C is a "web created issue"
    in the days of printed datasheets Philips (NXP is post web) always used I²C
    anyhow i2c is even worse than I2C
    Thus, when you can, use the right thing, when you can't, alas...
  • No, it isn't.
    It was common before the web, when wordprocessors and printers weren't as smart as they are now.
    It always has been common to do it in plain text files.
