Dear all,
Thanks for all, My qutions towards replies
I want to design a current limiting circuit (IC based) Speck for that design: Input:25,+/-1V Output:24V Imax:160mA or 0.16A Output Powewr:4 Watts,
application of above circuit is, i am using ULN2803A when i connet my load to the ULN2803A the overall 8 pins output current at the time of load should be 160mA, so if my current limit exceds above circuit should be play a role in such way that limit the current
Input:25,+/-1V Output:24V so, at Vi min (24V) you want a current limiter with no voltage drop? next are you going to post about a perpetuum mobile?
What does that have to do with Keil?
www.catb.org/.../smart-questions.html
