I am developing a project on IR based remote control switch using 89C2051 uC. I am using Keil uV2 for compiling the code. I have tested my code on a different uC 89V51RD2 and it works fine. But when I am testing it on 89C2051, the uC behaves strangely, sometimes it works fine but sometimes it doesn't boot at all and nothing happens.
I want to know that is there any kind of special setting in Keil uv2 for 2051 uC, or is there something else which I should take care for 2051 uC.
My code is:
int main() { TCON = 0x01;// IE = 0x81; // For External Interrupt P3.2 EA = 1; EX0 = 1; led = 0; toggle = 0; delay(); #if MEM toggle = read(0x00); // Passing the addr #endif while(1) {} } void tsop_delay1() { #pragma asm mov R7,#255 ;1.728mS delay for each bit djnz R7,$ mov R7,#255 djnz R7,$ mov R7,#255 djnz R7,$ mov R7,#30 djnz R7,$ #pragma endasm } void tsop_delay2() { #pragma asm mov R7,#255 ;1.296ms delay for each bit djnz R7,$ mov R7,#255 djnz R7,$ mov R7,#87 djnz R7,$ #pragma endasm } void compare_and_set_cmd(int cmd) { if(cmd == 0x01) { /* Decimal 2*/ toggle = !toggle; #if MEM write(0x00, toggle); #endif led = !led; } } void ext_interrupt(void) interrupt 0 { int fieldbit=0, flip=0, addr=0, cmd=0; int i; if(!tsop) { // 1st bit = 1 tsop_delay2(); fieldbit = !tsop; // 2nd bit = 0 or 1 tsop_delay1(); flip = !tsop; // 3rd bit 0 or 1 tsop_delay1(); for(i=0; i<5; i++) { // 4th to 8th bit = address bits addr |= !tsop; addr = addr << 1; tsop_delay1(); } addr = addr >> 1; for(i=0; i<6; i++) { // 9th to 14th bit = command bits cmd |= !tsop; cmd = cmd << 1; tsop_delay1(); } cmd = cmd >> 1; compare_and_set_cmd(cmd); } }
Please help!
