Hi. I'm having a problem with a very simple code. When I run it with te computer using Keil it works fine, but when I send it to the micro controller it doesn't work. I don't think it's the device that I'm using to send the program to the controller, because it works fine when i send a similar code in assembly language. The problem is when i use C. Here is the code:
#include <REGx52.H> void seteo_inicial (void); int main (void){ seteo_inicial (); while (1){ ACC=1; } return 1; } timer0_int () interrupt 1{ TR0=0; TR1=0; TH0=0xfb; TL0=0x00; TL1=0x00; TH1=0xfd; P2=0xff; TR1=1; TR0=1; } timer1_int () interrupt 3{ TR1=0; P2=0x00; } void seteo_inicial (void){ P2=0x00; IP=0x22; TR0=0; TR1=0; IE=0xaa; TMOD=0x11; TH0=0xfb; TL0=0x00; TR0=1; }
The port 2 should be changing its value from 0x00 to 0xff continuously, but this isn't the case, and i don't know why. Can someone help me with this?
Thanks Tomas
Just a question: You feel you get too long compilation times if you add comments to the source code lines?
It s a very sinple code... I think everybody can understand it only by looking it for two minutes...
So why are you then here with problems?
in 2 minutes I can make some $$ or try to figure out your scribbles (code has comments, scribbles do not) what do you think I prefer?
The OP also fails to realize that when we see comments, we can point out where the expectations of the comments doesn't match the results of the source lines.
Just looking at a number of assigns, I'm not really likely to care what the lines does which means the OP will spend his time with out responses.
