Hi everybody I'm trying to use 'Sourcery CodeBench Lite for ARM EABI' to assemble my ARM assembly files in Keil. I have changed my project tool chain configuration for Keil(in Components Environment And Books), and when I use Keil 4.1 everything works well. But I have a problem when I use Keil 4.6-4.7 for assembling files. Keil will not be able to find GNU assemble of CodeBench(with same setting that works in Keil 4.1) and generates following error: Error: failed to execute 'arm-none-eabi-as' Any idea why does this error happen?
Regards
Perhaps because an EXE of this name does not in fact exist, or that you've failed to provide a suitable PATH for the tools to find this executable?
All executable files with 'arm-none-eabi-' prefix run correctly in command prompt and this shows that PATH variable has been configured correctly but Keil MDK can not run them.
Hello Mojtaba Jafariqamsari,
Did you check that your project settings under TAB Components, Environment and Books - Folders/Extensions fit to your GCC installation?
The GNU-Tool Folder must contain the path to your GCC installation. One folder level obove the bin folder. If you are using Win7 than it should be something like :C:\Program Files (x86)\CodeSourcery\Sourcery G++ Lite\. The GNU-Tool-Prefix must contain the used prefix for the GCC executables.
Best Regards, Martin Guenther
Dear Martin,
I noticed what the problem was. When I was specifying GNU-Tool Folder, I was used a path to bin folder like this: C:\Program Files (x86)\CodeSourcery\Sourcery G++ Lite\bin\ Because executable files are located in this folder. But after your reply, I noticed that I should specify root folder like this: C:\Program Files (x86)\CodeSourcery\Sourcery G++ Lite\
Thanks a lot for help, this solved my problem. :)
