nested interrupt problem
hi
I'm using MDK arm uvision4 and LPC2368 , and i wanna use nesting interrupts ,and i'm using this code to do that :
#define IENABLE                      /* Nested Interrupts Entry */   \
  __asm { MRS     LR, SPSR      }    /* Copy SPSR_irq to LR     */   \
  __asm { STMFD   SP!, {LR}     }    /* Save SPSR_irq           */   \
  __asm { MSR     CPSR_c, #0x1F }    /* Enable IRQ (Sys Mode)   */   \
  __asm { STMFD   SP!, {LR}     }    /* Save LR                 */   \
#define IDISABLE                      /* Nested Interrupts Exit */   \
  __asm { LDMFD   SP!, {LR}     }     /* Restore LR              */   \
  __asm { MSR     CPSR_c, #0x92 }     /* Disable IRQ (IRQ Mode)  */   \
  __asm { LDMFD   SP!, {LR}     }     /* Restore SPSR_irq to LR  */   \
  __asm { MSR     SPSR_cxsf, LR }     /* Copy LR to SPSR_irq     */   \
and using these code (IENABLE and IDISABLE) at the beginning and end of each interrupt , but when an interrupt e.g external interrupt 1 happens then during it e.g I2c happens the I2c interrupt won't work , i checked it the Vector address value won't change after the I2c interrupt ,
By the way they work fine separately .
i wanna know what could be wrong ?
thank you ...
