Hi I want to use rtc in cmsis but I faced with this error would you please help me linking... flash_fs.axf: Error: L6218E: Undefined symbol CLKPWR_ConfigPPWR (referred from lpc17xx_rtc.o). flash_fs.axf: Error: L6218E: Undefined symbol check_failed (referred from lpc17xx_rtc.o).
you are "building" the project. before building the entire project, Compile individual files. this helps you to check if there are any errors in individual C source files.
Compile the lpc17xx_rtc.c file. You will see some errors. try to solve those errors.
errors mean: CLKPWR_ConfigPPWR & check_failed symbols used in the file "lpc17xx_rtc.c" are not defined.
thanks How can I compile just lpc17xx_rtc.c file ??(right click an then translate?) when I translate lpc17xx_rtc.c there is no error
compiling lpc17xx_rtc.c... C:\Keil\ARM\CMSIS\Drivers\lpc17xx_rtc.c(734): warning: #186-D: pointless comparison of unsigned integer with zero C:\Keil\ARM\CMSIS\Drivers\lpc17xx_rtc.c(758): warning: #186-D: pointless comparison of unsigned integer with zero C:\Keil\ARM\CMSIS\Drivers\lpc17xx_rtc.c - 0 Error(s), 2Warning(s).
CLKPWR_ConfigPPWR used like this in lpc17xx_rtc.c
void RTC_Init (LPC_RTC_TypeDef *RTCx) { CHECK_PARAM(PARAM_RTCx(RTCx)); /* Set up clock and power for RTC module */ CLKPWR_ConfigPPWR (CLKPWR_PCONP_PCRTC, ENABLE); // Clear all register to be default RTCx->ILR = 0x00; RTCx->CCR = 0x00; RTCx->CIIR = 0x00; RTCx->AMR = 0xFF; RTCx->CALIBRATION = 0x00;
what should I do?
If you are not getting any errors, that means the compilation is ok. (to "Translate" press "Ctrl+F7" _Shortcut keys_)
Now, "CLKPWR_ConfigPPWR" is a function called from your "lpc17xx_rtc.c" file, but the linker is unable to find the function (in the "lpc17xx_rtc.c" file).
i m sure that the function is defined in some other file. may be "lpc17xx_clkpwr.c" file!!
so how do you tell(inform) the linker that the function code exists in some other file?
thanks I Add "lpc17xx_clkpwr.c" file to my project so, I don't face with that error but I have 1 error yet linking... flash_fs.axf: Error: L6218E: Undefined symbol check_failed (referred from lpc17xx_rtc.o).
I'm found it!!!
check_failed function is in "lpc17xx_libcfg_default.c"
thanks in advanced
