void xx(char cc) { char aa; switch(cc) { case 1:case 0: aa=1; break; case 2,3: aa=2; break; } }
xx(0); //run OK xx(1); //run OK xx(2); //run FAIL <<***************** xx(3); //run OK
case 2,3:
You sure you understand what that will do?
The comma is probably one of the more misunderstood operators in C.
And because of what it does, the compiler will silently accept code that does something completely different from what the user may think.
But in this case, I'm a bit surprised. I didn't think C would allow a comma expression in a case statement.
The language standard says that the keyword "case" takes a constant expression.
And that a constant expression "shall not contain assignment, increment, decrement, function-call, or comma operators, except when they are contained within a subexpression that is not evaluated."
So I would have expected a compilation error and not a problem at runtime, since the comma operator is explicitly mentioned as not allowed.
0 Error(s) 0 warning(s) ,you can step test
No need to step test. It doesn't matter if the compiler should have accepted that expression or not. The source code is incorrect. And you can't expect correct behaviour if the source code is incorrect.
0 Error(s) 0 warning(s) ,you can step test I know of no C compiler that catches and report each and every possible mistake.
But it should catch invalid syntax!
I know of no C compiler that catches and report each and every possible mistake although they should
'should' is such a wonderful word
you should stop smoking you should eat healthy you should exercise regularly you should .....
PS I do agree that someone with a current license should report this to Keil, if anyone lese does it is more certain it will be ignored. I am nor working Keil at this place.
In my opinion, you should attend a good, taught class.
There again, if you're like me you won't have the time to do anything like that because you'll be way too busy keeping an eye on every post on every forum and posting the same old non-specific crap.
