Problem of migration to LPC1788 for ethernet
I have done a project on the LPC1768, which works very well.
I had to change the micro to add more ram. I took the LPC1788.
I use the last version RL of Keil.
But I have a problem with the ethernet does not work.
I watched all the ethernet registers but they are identical with the LPC1768.
I just changed in the file "EMAC.c", the configuration of pins which are different.
I check in debug mode, the configuration of pins are good.
The micro communicates with the PHY.
But when I send data to TCP, I see nothing move in wireshark.
In debug mode, when I do tcp_get_state(socket), it always returns TCP_STATE_SYN_SENT. It never goes in the state TCP_STATE_CONNECT.
I do not understand why it does not work.
is what I miss something?
an idea?
Thanks.
JB
