I met on odd experience when create a new uVision project by using NXP LPC1114.
I have sample uVision project (.uvproj extension), then build, download and debug it. Everything work fine. In debug session, I can step into, step over.
When I create new uVision project, it contains system created startup_LPC11xx.s. I added all sample files, build and download both successfully. When I try to start debug session, it terminated and without any error message (previous version of uVision V4.03 prompted "cannot load axf file").
I have already read question on cannot load axf file, but such method cannot solve my problem.
http://www.keil.com/forum/12732/,/ http://www.keil.com/support/docs/3411.htm
All environment settings are same in sample and my new uVision project.
Is there a limitation on create new project when using Evaluation License? Many thanks.
My IDE-Version: µVision V4.23.00.0 Copyright (C) 2011 ARM Ltd and ARM Germany GmbH. All rights reserved.
Tool Version Numbers: Toolchain: MDK-Lite Version: 4.23 Toolchain Path: C:\Keil\ARM\BIN40 C Compiler: Armcc.Exe V4.1.0.894 [Evaluation] Assembler: Armasm.Exe V4.1.0.894 [Evaluation] Linker/Locator: ArmLink.Exe V4.1.0.894 [Evaluation] Librarian: ArmAr.Exe V4.1.0.894 [Evaluation] Hex Converter: FromElf.Exe V4.1.0.894 [Evaluation] CPU DLL: SARMCM3.DLL V4.23 Dialog DLL: DARMP1.DLL V1.22.0.6 Target DLL: Segger\JL2CM3.dll Dialog DLL: TARMP1.DLL V1.22.0.6
