typedef struct { char * SongName; unsigned char * SongDir; unsigned int SongIndexInGroup; unsigned int SongPlaying; }SongInformation; typedef struct song_link { SongInformation SongInfo; unsigned int SongPLayed; struct song_link * next; }SongList,*pSongList; const char* GROUP_MUNO_MP3_Name[GROUP_MUNO_MP3_NUM] = {"2.mp3","3.MP3","4.MP3"}; pSongList CreateList(unsigned char **SongGroup,unsigned char len) { SongList *head,*newNode, *rail; unsigned int i; i = sizeof(SongGroup); head = (pSongList) malloc(sizeof(SongList)); rail = head; head->SongInfo.SongName = SongGroup[0]; head->SongInfo.SongIndexInGroup = 0; head->SongInfo.SongPlaying = FALSE; for(i=1;i<len;i++) { newNode = (SongList*) malloc(sizeof(SongList)); newNode->SongInfo.SongName = SongGroup[i]; newNode->SongInfo.SongIndexInGroup = i; newNode->SongInfo.SongPlaying = FALSE; rail -> next = newNode; rail = newNode; } rail -> next = NULL; return head; } CreateList(GROUP_MUNO_MP3_Name,GROUP_MUNO_MP3_NUM);
But when I debug into CreateList,the list member can not be assigned correctly.But this source code is correct in vs2008.So what should i change for keil mdk?
You don't even tell what problem you have...
By the way - have you made sure you have any memory reserved for a heap, i.e. does malloc() return any pointer?
And why do you have a struct where the SongDir pointer doesn't get an initial value?
And why an integer for storing a boolean value?
And why you you mix char* and unsigned char* for the song names?
Why the dummy assign of sizeof(SongGroup) pointer to i?
Is the value of GROUP_MUNO_MP3_NUM 3?
