Hi, I have a problem about Global Pointer of an Object. Here is my simple code
#include "LPC17xx.h" #include "class.h" Class1* Pot; /* Interrupt every 100ms */ extern "C" void SysTick_Handler(void) { LPC_GPIO2->FIOPIN ^= (1<<0); //Toggle Led1 } int main(void) { SystemInit(); SysTick_Config(SystemFrequency / 10); //100ms Pot = new Class1(0, 0); LPC_GPIO2->FIODIR |= (1<<0); //Led 1 as Output while(1); }
Don't care about what is "class". In this way I created a global pointer of an object and I want to associat it to a real object.
During compiling noError occur, but when I flash my LPC1768 usinf Keil uVision and ULINK2, nothing happen. NO Led Blink NO Debug mode it's seems no flash was written in it.
If I comment //Pot = new Class1(0, 0);
Led Blinks and Debug mode works.
I think it's a "Configuration/option" issue. Someone can help me? thanks, Walter
Did you care about that memory region called "heap", where "new" will look for memory for that new object?
You're right!!!
in file "startup_LPC17xx.s" heap size was set as 0x00
Heap_Size EQU 0x00000000
It was enough rise it setting as
Heap_Size EQU 0x00000200
And everything begin to work!!
Thank you so much
Walter
