Hi, I have some code that hangs periodically, but do not know how to setup the watchdog control register to initialise for processor reset and reset timeout. I also need to know how to reset the watchdog in normal use to prevent a reset.
If I can get the watchdog running I can work on the problem that causes the latch up later.
Any help will be very much appreciated - using Keil Realview -
Regards Rob aspey@alumni.caltech.edu
Hi, >>I have some code that hangs periodically, but do not know how to setup the watchdog control register to initialise for processor reset and reset timeout.
How you initializing the watchdog in your code can you post the code bit...? and did you enabled interrupts..?
Regards Thiru N
What does the Datasheet say?
Have you searched the manufacturer's website for examples, application notes, etc...?
I have some code that hangs periodically, but do not know how to setup the watchdog control register to initialise for processor reset and reset timeout. It is good to have a fire extinguisher, but you do not want to have to use it.
