I have problem with Keil example for Infineon Relax Lite Kit (blinky). When i dowload code to board and run debugger, the LED on the board don't blinking.
Best regards
Andrzej Niedworok
Are you sure that you're actually running the debugger - not just the simulator...?
Yes, I'm sure... I run debugger (and press RUN icon).
Andrzej
The RUN button starts either the Simulator or the target debugger - you have to have the correct one selected before you press the button.
i run debugger in target mode :-). But my LED is off.
AN
So single-step your code and see what's happening...
I find problem. In KEIL code, in file led.c in function "void LED_Init (void);"
is ...
#else /* configure PORT P1.0..1 pin as output */ PORT2->IOCR0 &= ~((0xFFUL << 0) | /* clear P1.0 settings */ (0xFFUL << 8) ); /* clear P1.1 settings */ PORT2->IOCR0 |= ((0x80UL << 0) | /* P1.0 output push pull */ (0x80UL << 8) ); /* P1.1 output push pull */ PORT2->PDR0 &= ~((0x07UL << 0) | /* clear P1.0 output settings */ (0x07UL << 4) ); /* clear P1.1 output settings */ PORT2->PDR0 |= ((0x02UL << 0) | /* P1.0 output strong */ (0x02UL << 4) ); /* P1.1 output strong */ #endif
should be ...
#else /* configure PORT P1.0..1 pin as output */ PORT1->IOCR0 &= ~((0xFFUL << 0) | /* clear P1.0 settings */ (0xFFUL << 8) ); /* clear P1.1 settings */ PORT1->IOCR0 |= ((0x80UL << 0) | /* P1.0 output push pull */ (0x80UL << 8) ); /* P1.1 output push pull */ PORT1->PDR0 &= ~((0x07UL << 0) | /* clear P1.0 output settings */ (0x07UL << 4) ); /* clear P1.1 output settings */ PORT1->PDR0 |= ((0x02UL << 0) | /* P1.0 output strong */ (0x02UL << 4) ); /* P1.1 output strong */ #endif
And in project options in C/C++ card must be removed:
"__PROTOTYPE" definition
Good of Keil to test their code at least cursory before releasing it...
