keil verision
which keil microvision version can i use with lpc2129 and lpc2148
  • Most. But you want something like the MDK-ARM package since you want the ARM compiler backend.
  • which keil microvision version can i use with lpc2129 and lpc2148
    there seems to be a lot of confoosion re uVision, e.g. today, in addition to the above, there is a post at the SILabs forum where someone does not undersatnd that PK51 does not accept ARM as chip type.
    uVision can NOT compile code for ANY processor
    MDK-ARM (which uses uVision as an IDE) can compile and link for many ARM processors
    PK51 (which uses uVision as an IDE) can compile and link for most (all?) 8051 type processors
    Erikm
