I'm working with the STM32F103ZET6 processor and I want to talk to another device connected to the external memory interface (device: ICS2008B). At the moment I'm not able to talk to the ICS2008B. Maybe there's something wrong in my init-code? At the NWE pin is no activity at all. The correct NCS goes low.
#define Bank1_SRAM3_ADDR ((unsigned int)0x68000000) volatile unsigned char *addr __attribute__((at(Bank1_SRAM3_ADDR))); void testfunction(void) { unsigned char progreg = 0x01; unsigned char uartstatreg = 0x00; SRAM_INIT(); //write access didn't work -> HardFault_Handler will be called *(unsigned int*)addr = progreg; //read access uartstatreg = *(unsigned char*)addr; } void SRAM_INIT(void) { FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure; FSMC_NORSRAMTimingInitTypeDef p; RCC->AHBENR |= RCC_AHBPeriph_FSMC; RCC->APB2ENR |= (RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOG | RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOF) ; GPIO_Init(GPIOD, GPIO_Mode_AF_PP, (GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15)); GPIO_Init(GPIOD, GPIO_Mode_AF_PP, (GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15)); GPIO_Init(GPIOF, GPIO_Mode_AF_PP, ( GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15)); GPIO_Init(GPIOG, GPIO_Mode_AF_PP, (GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |GPIO_Pin_4 | GPIO_Pin_5)); GPIO_Init(GPIOD, GPIO_Mode_AF_PP, (GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13)); GPIO_Init(GPIOD, GPIO_Mode_AF_PP, (GPIO_Pin_4 |GPIO_Pin_5)); GPIO_Init(GPIOG, GPIO_Mode_AF_PP, (GPIO_Pin_10)); GPIO_Init(GPIOE, GPIO_Mode_AF_PP, (GPIO_Pin_0 | GPIO_Pin_1)); p.FSMC_AddressSetupTime = 3; p.FSMC_AddressHoldTime = 0; p.FSMC_DataSetupTime = 2; p.FSMC_BusTurnAroundDuration = 0; p.FSMC_CLKDivision = 0; p.FSMC_DataLatency = 0; p.FSMC_AccessMode = FSMC_AccessMode_A; FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3; FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM; FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b; FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable; FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low; FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable; FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable; FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p; FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p; FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure); /*!< Enable FSMC Bank1_SRAM Bank */ //FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE); FSMC_Bank1->BTCR[FSMC_Bank1_NORSRAM3] |= BCR_MBKEN_Set; }
best regards Jens
Hello Jens. Can I talk to you about your post and my project by email? If so, Please send me an email to khashayar81@hotmail.com.
Best regards Ciro
