SDCC error
I am trying to convert this simple code to SDCC (due to chaninging to Linux):
// main.c
#include <t89c51cc01.h>
#include <stdio.h>
#include <lcd.h> // my own lcd header file
int i = 0;
void main()
    char txt[17];
    lcd_init();
    while (1)
        lcd_home();
        sprintf(txt, "Zahl: %i", i);
        lcd_send_text(txt);
void gelb() interrupt 0
    i++;
The "lcd.h" header:
// LCD header file
#ifndef _lcd_H_
#define _lcd_H_
#define DIS_ON_1 2 // to be continued
void lcd_init();
void lcd_display();
void lcd_dis_on(unsigned char i);
void lcd_dis_off();
void lcd_store();
void lcd_clear();
void lcd_send_char(unsigned char c);
void lcd_send_text(char *t);
void lcd_position(unsigned char p);
void lcd_home();
void lcd_wait();
void lcd_sec(unsigned char i);
void lcd_msec(unsigned char i);
#endif // _lcd_H_
With Keil, all worked fine. With SDCC, following code:
// main.c
#include <mcs51/8051.h>
#include <stdio.h>
#include <lcd.h>
int i = 0;
void main()
    char txt[17];
    lcd_init();
    while (1)
        lcd_home();
        lcd_send_text(txt);
    i++;
I get the following errors:
?ASlink-Warning-Undefined Global '_lcd_home' referenced by module 'main'
?ASlink-Warning-Undefined Global '_lcd_init' referenced by module 'main'
?ASlink-Warning-Undefined Global '_lcd_send_text' referenced by module 'main'
It creates the .ihx file, tho...
Can anyone of you figure out what's wrong? I hope this is the right place to ask...
Thanks in advance =)
