Hello, I am working on an ARM Cortex M3, with IDE Keil uV4. The Keil compiler generates only hex format file. I would need to generate a Motorola S-Record file.
Is possible? How can I do?
Davide
There must be hundreds of tools for converting hex files to/from other formats out there. Pick one. srecord is one of the more well-known.
I also suggest you check the correctness of that assertion once more...
Maybe:
Converting an ELF image to Motorola 32-bit format http://www.keil.com/support/man/docs/armutil/armutil_cacbgfac.htm
