Hi all
I have a strange problem with getting an input to generate an interrupt. I probably have missed something, but I cant see what.
I'm trying to use P2.10 to generate GPIO interrupt on both falling and rising edges.
I set the P2.10 as an input I install the EINT3 interrupt vectore (shared with GPIO interrupts I set the rising and falling edge enable flag for the P2.10 input
But no interrupt is coming when I activate the input.
I have verified the settings with the 'Peripherals' in uVision4 and VIC, GPIO interrupt and GPIO seems to be setup ok.
Also, after I have set the P2.10 input, I can see the correct flag being set in the IO2_INT_STAT_R in the Peripherals->GPIO Interrupts and the IO2_INT_STAT_F when the input is released again.
When I use the P2.10 as an external interrupt (EINT0), I can get an interrupr with no proglem.
I just want to use both edge..
Im using a LPC2478 and KEIL uvision
any Ideas?
Code:
int main (void) { // LED GPIOInit( 3, 27, FAST_PORT, DIR_OUT ); // Status LED // Input GPIOInit( 2, 10, FAST_PORT, DIR_IN ); // Reset // Clear it... just in case IO2_INT_CLR = (0x00000001<<10); // Install the EINt3 install_irq(EINT3_INT, (void (*)( void ))EINT3_Interrupt, HIGHEST_PRIORITY+1); // enable rising and falling edge IO2_INT_EN_R |= (0x00000001<<10); IO2_INT_EN_F |= (0x00000001<<10); // Forever while(1); } // EINt3 IRQ handler void EINT3_Interrupt (void) __irq { if(IO2_INT_STAT_R) FIO3CLR |= (0x0001 << 27); if(IO2_INT_STAT_F) FIO3SET |= (0x0001 << 27); IO2_INT_CLR = (0x00000001<<10); VICVectAddr = 0; }
thomas
