P89V664 Serial Graphical LCD Problem
Hello
I have confused in the coding of the Serial Graphical LCD on NXP P89V664.
Can any one help ????
the code is
#include<reg52.H>
#include<stdio.h>
#include<intrins.h>
// #define unsigned char unsigned char // 0~255
// #define unsigned int unsigned int   // 0~65535
sbit _CS = P2^3;
sbit _RST = P2^2;
sbit A0 = P2^1;
sbit SCK = P4^0;
sbit DIN = P4^2;
unsigned char ContrastLevel;     // for contrast setting level
// dispaly data (128x64)
unsigned char code Logo[]={
....0x15,0x06,0x00,0x00,0x10,0x1F,0x10,0x00,0x00,0x12,0x15,0x15,0x15,0x88,0xC0
// Delay Routine
void delayms(unsigned int m)        // 12MHz Xtal, close to ms value
    unsigned int j;
    unsigned int i;
    for(i=0; i<m; i++)
        for(j=0; j<109; j++)
            _nop_();
// IO Routine
void lcd_cmd(unsigned char Command)       //send command
    SCK = 1;
    A0  = 0;
    _CS = 0;
    DIN = Command & 0x80; SCK= 0; SCK= 1;
    DIN = Command & 0x40; SCK= 0; SCK= 1;
    DIN = Command & 0x20; SCK= 0; SCK= 1;
    DIN = Command & 0x10; SCK= 0; SCK= 1;
    DIN = Command & 0x08; SCK= 0; SCK= 1;
    DIN = Command & 0x04; SCK= 0; SCK= 1;
    DIN = Command & 0x02; SCK= 0; SCK= 1;
    DIN = Command & 0x01; SCK= 0; SCK= 1;
    _CS = 1;
void lcd_data(unsigned char DData)        //send data
    SCK= 1;
    A0  = 1;
    _CS = 0;
    DIN = DData & 0x80; SCK= 0; SCK= 1;
    DIN = DData & 0x40; SCK= 0; SCK= 1;
    DIN = DData & 0x20; SCK= 0; SCK= 1;
    DIN = DData & 0x10; SCK= 0; SCK= 1;
    DIN = DData & 0x08; SCK= 0; SCK= 1;
    DIN = DData & 0x04; SCK= 0; SCK= 1;
    DIN = DData & 0x02; SCK= 0; SCK= 1;
    DIN = DData & 0x01; SCK= 0; SCK= 1;
    _CS = 1;
// Write a Screen
void WriteScreen(unsigned char *DisplayData)    // DisplayData should be 164x64/8 = 1312byte
    unsigned char TempData;
    unsigned char i, j;
    for(i=0;i<8;i++)
        lcd_cmd(0xb0 | i);    // select page 0~7
        lcd_cmd(0x10);        // start form column 4
        lcd_cmd(0x00);        // (2byte command)
        for(j=0;j<128;j++)
            TempData=(*(DisplayData+(i*128)+j));
            lcd_data(TempData);
// Contrast control
void LCD_Darker(void)
    if (ContrastLevel<0x3F)
        ContrastLevel++;
    lcd_cmd(0x81);            // E-Vol setting
    lcd_cmd(ContrastLevel);   // (2byte command)
void LCD_Lighter(void)
    if (ContrastLevel>0x00)
         ContrastLevel--;
// Init LCD module
void initLCDM(void)
    _RST=1;                 // hardware reset LCD module
    _RST=0;
    delayms(1);
    _RST=1;
    delayms(800);
    ContrastLevel=0x17;     // default Contrast Level  1a
    lcd_cmd(0xab);                      //new
    lcd_cmd(0xaf);            // display on
    lcd_cmd(0x40);            // display start line=0
    lcd_cmd(0xc8);            // Common output mode select= reverse
    lcd_cmd(0xa6);            // normal display
    lcd_cmd(0xa4);            // Duisplay all point = off
    lcd_cmd(0xa3);            // LCD bias = 1/9   a2
    lcd_cmd(0x2f);            // Power control = all on
    lcd_cmd(0x25);            // Rab Ratio     26
// Main Program
void main()
    SP=0x60;
    EA = 0;         // disable interrupts
    _CS    =1;
    _RST   =1;
    A0     =1;
    SCK   =1;
    DIN    =1;
    initLCDM();
    WriteScreen(Logo);
    while(1)
//end of program
The error it shoes that P4 is an undefined identifier. error C202
  • This is the code for the serial graphical LCD I am using for sending the serial data to the lcd on four lines but it does not give any result at the end.
    It shows the raster image on the graphical lcd so please help for further for sending the lcd data on four lines
    #include <stdio.h>
    #include <config.h>
    #include <lcd128x64.h>                                    // definitions for the LCD controller
    #include <fonts.h>                                                // definitions for the fonts
    // MAIN Routine
    sbit SWT = P2^4;                                        /* eval board switch */
    void main (void)
            config();                                                               // setup all the SFR initialization
            lcd_init();                                                             // initialize LCD display
            lcd_erase();                                                    // erase the display
            while(1)
                    lcd_clear_area(SCRN_LEFT,SCRN_TOP,SCRN_RIGHT,SCRN_BOTTOM);
                    lcd_box(SCRN_LEFT,SCRN_TOP,SCRN_RIGHT,SCRN_BOTTOM);
                    lcd_box(SCRN_LEFT+2,SCRN_TOP+2,SCRN_RIGHT-2,SCRN_BOTTOM-2);
                    lcd_text(4,4,FONT_NINE_DOT," Priyank Rathod");
                    lcd_text(6,29,FONT_NINE_DOT,"128x64");
                    lcd_text(60,32,FONT_SEVEN_DOT," Toggling");
                    lcd_text(17,52,FONT_SIX_DOT,"">http://www.google.com");
                    lcd_update(SCRN_TOP,SCRN_BOTTOM);
                    while(SWT == 1);
                    while(SWT == 0);
                    lcd_invert_area(SCRN_LEFT+3,SCRN_TOP+3,SCRN_RIGHT-3,SCRN_BOTTOM-3);
                    while(SWT == 1);
                    while(SWT == 0);
