Linker / place CRC Checksum in AXF File
Is it possible to instruct the linker (target is an STM32) to place a CRC checksum on the code in the AXF file at a certain location without using any external tools? If yes, what is the crc width, polynomial and start value?
Reason for asking: I am aware that it could be done with using "fromelf" to convert the AXF to .bin and then place a checksum in the file. However this process is a nightmare when handing over an image to production. Working with external tools is always error prone and I'd rather have the Compiler / Linker add the CRC in the binary without any further intervention or use of external tools.
Many thanks in advance.
Christopher Lang
  • Is it possible ...
    As far as I know, no.
    I can see no reason for that.
    No, it isn't. If you set it up right, everything works automatically. Automatic processes are not error-prone.
  • thanks for clarifying. Well, in this case we will set up an automatic post link step and do the .bin conversion and checksum calculation there.
    Maybe Keil/ARM could take that as a suggestion for the feature "wishlist". Automatic embedding of a CRC by the linker into the AXF file would be quite useful.
    thanks
    Chris
