I'm working in a Project. We have bought the MCBstm32F400 Dev. Board.
I haved configured the ADC sampling time equal to 1MSPS as follows:
System clock =30MHz(HSI) SPB preescaler = 1-> PCLK = 30MHz.
-I'm using ADC3 -ADC_preescaler= Div2 -> ADC_clock= 15MHz. -ADC sampletime= 3 cycles -ADC channel= 4
conversion time=( 3+12)/15MHz= 1us = 1MHz. I use the Excel file to configure the clock.
next is the code to configure the ADC:
/* Private typedef -----------------------------------------------------------*/ # define N_samples 100 /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ ADC_InitTypeDef ADC_InitStructure; ADC_CommonInitTypeDef ADC_CommonInitStructure; GPIO_InitTypeDef GPIOADC_InitStructure; /* Private function prototypes -----------------------------------------------*/ uint32_t index=0; float32_t array2[N_samples]; /* Private functions ---------------------------------------------------------*/ /** * @brief Main program * @param None * @retval None */ int main(void) { //1. Enable the ADC interface RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE); //3. Configure the ADC Prescaler, conversion resolution and data // alignment using the ADC_Init() function. /* ADC Common Init(Configure the ADC Prescaler) **********************************************************/ ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent; ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2; //ADCclock= PCLK2/2= 36Mhz/2=18MHz ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled; ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles; ADC_CommonInit(&ADC_CommonInitStructure); //conversion resolution and data alignment ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b; ADC_InitStructure.ADC_ScanConvMode = DISABLE; ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; //ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right ; ADC_InitStructure.ADC_NbrOfConversion = 1; ADC_Init(ADC3, &ADC_InitStructure); ADC_RegularChannelConfig(ADC3, ADC_Channel_4, 1, ADC_SampleTime_3Cycles);//sampletime= ADC_clock/(3+12)= 18MHz/15=1.2MHz //2. ADC pins configuration RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE); GPIOADC_InitStructure.GPIO_Pin = GPIO_Pin_6;//PF9 GPIOADC_InitStructure.GPIO_Mode = GPIO_Mode_AN ;// PIN 9 IN ANALOGUE MODE GPIOADC_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOF, &GPIOADC_InitStructure); //4. Activate the ADC peripheral using ADC_Cmd() function. ADC_Cmd(ADC3, ENABLE); /* Get the N ADC samples */ for (index=0; index<N_samples; index++) { /* ADC start conv */ ADC_SoftwareStartConv(ADC3); /* Wait end of conversion */ while(ADC_GetFlagStatus(ADC3,ADC_FLAG_EOC) == RESET); /* Store ADC samples*/ array2[index]= ADC_GetConversionValue(ADC3)-2048;
problem: Configured sampling time does not match with real sampling time.
I put a square signal of 15KHz to get more or less 66 samples(1MHz/15KHz). I see the results in the Watch window:
-2045 , -2034 , -2032 , -2037 , -2040 , -2036 , -2036 , -2041 , -2038 , -2041 , 2039 , 2036 , 2033 , 2031 , 2034 , 2039 , 2037 , 2031 , 2036 , 2038 , -2048 , -2042 , -2039 , -2040 , -2041 , -2041 , -2038 , -2042 , -2041 , -2036 . . . repeats itself
The input signal freq is 15KHz, and there are 20 points per cycle therefore , the real sampling time is: (x/15KHz)= 20 -> x= 300KHz.
what did I do wrong???
Thank you very much.
