Sometimes keil hangs in V4.70 & have to close the program & unsaved code gets lost.
1. In some thread I saw other people also have same problem. 2. Does it has been fixed in v4.70a
"Does it has been fixed in v4.70a"
No. See following thread for details of changes:
http://www.keil.com/forum/22396/
DJR
Hi I am getting following details:
Problem Event Name: APPCRASH Application Name: UV4.EXE Application Version: 4.70.0.0 Application Timestamp: 51125381 Fault Module Name: UvCC.dll Fault Module Version: 0.0.0.0 Fault Module Timestamp: 50f66757 Exception Code: c0000005 Exception Offset: 0001c01e
Have you reported those details to Keil?
http://www.keil.com/pr/article/1256.htm
OK, I wonder what the price tag will be...
can you send the reproducer code/project to our support team?
I did a beyond compare of the Backup.001 (containing 4.70) to 4.70A, there seems to be more changes than just help file issues. So far, I had no issues, except debug failure, when my relays switch on / off probably due to EMI (I had this with 4.60 as well). Then the system hangs until I unplug ULINK ME from USB.
Werner
PS. automatically save files before debug start seems to be a good idea. In Edit > Configuration. Seems that these settings are not taken from previous installation. Neither are "Create Backup files (*.BAK)
"I did a beyond compare of the Backup.001 (containing 4.70) to 4.70A"
I just did a byte-for-byte comparison of all files between 4.70 and 4.70a. Only differences I see are in setup.ini, Release_Notes.htm (which are to be expected) and in 41 .chm files.
